Multiple batteries
TAudio
Copper - Posts: 64
Posted: September 23, 2003 at 9:25 AM / IP Logged
I have a 1995 Acura Integra with a JVC KD-S990 head unit, Pioneer 6 1/2 components running of a Coustic 161SE 2 chanel amp, and a Coustic CF124 sub running off a Coustic 401SE 2 chanel amp (bridged, 400 watts RMS @ 4 ohms).  As may people probably know in this forum, honda products have nutoriously small bateries and I killed two with my old system that only drew about half as much current.  I want to set up a 2 battery system to give have more amps available at all times.  In talking with a couple aqaintances I wal lead to beliueve that unless an isolation circuits is used (which I have no idea how to set up) that the batteries must be wired in parallel (which makes sense) and that they must be identical batteries (?).  If this is so, why?  I know that many of you will say just get a cap, but I will be adding a second sub and changing over to an amp that pots out 800 watts RMS in a few months so I will need the higher voltage.  The expert advice of more experienced members would be greatly appreciated.
If quiters never win, and winners never quit, who the heck came up with the idea that you should quit while your ahead?
bberman1
Gold - Posts: 2,314
Posted: September 23, 2003 at 9:49 AM / IP Logged
The only thing adding a 2nd battery will do for you is allow you to listen to your radio with the cars engine off for a longer amount of time, or allow you to drain your accessories battery and still start the car depending on the way you set it up. . What you will need with or with out a 2nd battery is a high out put alternator. The alternator will give you the current you need, not adding a 2nd battery. If you do add the 2nd battery it will put more of a strain on your current underpowered charging system, since it now has to charge 2 batteries plus supply power to your cars electrical system and any stereo equipment you have. By putting in a high out put alternator it will be able to supply enough current for your car, as well as your aftermarket stereo system.
TAudio
Copper - Posts: 64
Posted: September 23, 2003 at 10:21 AM / IP Logged
Any recomendations on a good source for high output alternators?
mj239air
Copper - Posts: 153
Posted: September 23, 2003 at 10:35 AM / IP Logged
www.mechanicalman.com
bberman1
Gold - Posts: 2,314
Posted: September 23, 2003 at 12:02 PM / IP Logged
If you tell me the total RMS of you final setup, I can tell you  approximately how many amps your new high out put alternator should be
Dominick 615-287-7991, Michiana Rebuilders 1-800-627-4812,
 C.S.A 1-334-712-9955 or 1-334-791-6272, http://www.mechman.com/home.html
http://www.wranglernw.com
http://www.mralternator.com
http://www.alternatorparts.com
mray
Member - Posts: 9
Posted: September 23, 2003 at 10:16 PM / IP Logged
Can you tell me why my PPI a1200 running 300X2 into 4 ohms continually dims my lights on my 94 Caprice with a NEW battery and a 140 amp alternator? Running like a 2 gauge to the amp from the battery and a very short ground?
My other amp is an ADS 860 MX running 4X60rms....all watts shown are RMS.
71 Cheyenne ZZ502/400 LWB Chrome rallies...
66 Chevelle SS 427
98 C5 Corvette
1994 LT1 Caprice 9C1
2001 Suburban 8.1/496
02 VMAX
bberman1
Gold - Posts: 2,314
Posted: September 23, 2003 at 10:23 PM / IP Logged
If you park in front of a wall at night with your headlights on, and race your engine do the lights still dim? or dose it only happen at idle?
mray
Member - Posts: 9
Posted: September 23, 2003 at 10:46 PM / IP Logged
All the time. The harder the kick drum the lower my volt meter dips.
thats with lights only....no AC, no electric fans.....goin down the highway.....
66 Chevelle SS 427
98 C5 Corvette
02 VMAX
bberman1
Gold - Posts: 2,314
Posted: September 23, 2003 at 10:54 PM / IP Logged
I would have your alternator checked to make sure you’re getting the correct ampage. Also what is the size of your ground cable?
mray
Member - Posts: 9
Posted: September 23, 2003 at 11:07 PM / IP Logged
same as supply... 2 guage.
I am going to send you a message outside of this post, i have another question noone can seem to answer for me.
66 Chevelle SS 427
98 C5 Corvette
02 VMAX
