95 intrepid wire diagram
jbobbv
Posted: July 14, 2002 at 8:12 AM / IP Logged
Does anyone have a wire diagram for a 1995 dodge intrepid for alarm/starter.
jbobbv
installmaster
Posted: July 14, 2002 at 9:11 AM / IP Logged
  YEAR: 1995  MAKE: Dodge  MODEL: Intrepid  STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V |pink/black,red (20A) | +  |ignition harness            |
|             STARTER |yellow/gold dots     | +  |ignition harness            |
|            IGNITION |dk. blue/gold dots   | +  |ignition harness            |
|     SECOND IGNITION |RED / wht/gold dots    | +  |ignition harness            |
|      THIRD IGNITION |*3                   |    |                            |
|           ACCESSORY |BLACK/ orange         | +  |ignition harness            |
|          POWER LOCK |ORANGE / white *1      | +  |wht plug back of fuse panel |
|        POWER UNLOCK |pink/purple *1       | +  |wht plug back of fuse panel |
|    PARKING LIGHTS + |BLACK / YELLOW         |    |driver kick panel           |
|    PARKING LIGHTS - |                     |    |                            |
|          HEADLIGHTS |green                | +  |headlight switch            |
|        DOOR TRIGGER |tan & tan/red *2     | -  |driver kick panel           |
|     TRUNK/HATCH PIN |BROWN / black          | -  |driver kick panel           |
|            HOOD PIN |                     |    |                            |
| TRUNK/HATCH RELEASE |BLACK/ white          | +  |at switch                   |
|   FACTORY ALARM ARM |lock                 |    |                            |
|FACTORY ALARM DISARM |lt.GREEN/ orange 20ga | -  |either kick                 |
|          TACHOMETER |red, white, or black |    |at coil pack                |
|          BRAKE WIRE |white                | +  |at brake switch             |
|        HORN TRIGGER |BLACK/ red            | -  |relay in fuse panel         |
|              WIPERS |pink                 | +  |3 wire plug near wiper motor|
|   LF WINDOW UP/DOWN |lt.blu/gld - wht/gld | A  |in driver door              |
|   RF WINDOW UP/DOWN |brn/wht - pur/wht    | A  |in driver door or dkp       |
|   LR WINDOW UP/DOWN |blu/wht - RED / blk    | A  |in driver door or dkp       |
|   RR WINDOW UP/DOWN |gry/blk - grn/wht    | A  |in driver door or dkp       |
NOTES:
*1 Also find same colors in harness to right of glove box by passenger
kick panel.
*2 Tan gets drivers door, tan/red gets pass. doors. Tap both wires and
diode isolate.
*3 The SRS (air bag) warning light may come on after remote started, after
the key is inserted and the remote start shut down with the brake. If this
happens, find an 18ga (NOT 12ga) RED / white in the ignition harness. Power
it as an Ign 3 with an additional rela
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
