envoy 2002 help
babaface
Member - Posts: 7
Posted: September 28, 2003 at 6:46 PM / IP Logged
i have tried to jump start envoy 2002 after draining the battery now somehow it will not even crank the ignotion comes on but notting in the start position what could it be any idea is helpfull
thanks
ck auto
Copper - Posts: 257
Posted: September 29, 2003 at 6:14 PM / IP Logged
does the security light on the daash flash or is it solid if it's flashing turn key on wait till it stops flashing. then try to start if that does not do it try testing to see if you have power at the starter solenoid will cranking if you do try tapping starter while cranking.if you didn't put any aftermarket acc in yourself tow to dealer. still under warranty.if none of that helps,email me and maybe be able toi help
kirk
ck auto
Copper - Posts: 257
Posted: September 29, 2003 at 6:16 PM / IP Logged
sorry forgot to tell you msy tskr up to 1 hour with key on before security light stops flashing
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
