1995 Subaru Legacy amp install
mcgyvr420
Posted: September 30, 2003 at 1:58 PM / IP Logged
I'm trying to install an amp and subs in my Legacy which has the factory stereo with tape/cd. It has a power antenna that turns on when the radio is on, but turns off when the cd player is running. So in turn my amp shuts off when i play a cd. there are 3 wires leading to the pwr antenna- ground, switched, constant. I first connected it to the switched, but that was the one that turns off when you play a cd. I hooked it up to the constant, but then i found out the hard way that it doesn't ever shut off, even when the car is off, and you get a dead battery the next morning.
I read that a early 90's model Mazda did the same thing, and it said something about installing a relay. But I haven't had to install one of those before. What kind would I need and how would I do it? Thanks
Jason
Sweekster
Silver - Posts: 481
Posted: September 30, 2003 at 2:18 PM / IP Logged
You may want to try the positive on the cigarette light (in most japanese cars it's a switched acc wires).  That's what I did in my 97 altima.  Or you may just want to get a digital multimeter and check each wire in your radio harness plug and CAREFULLY  splice into it or use a wire tap.  Here's a wiring diagram that might help.  I'm assuming you're trying to find a way to connect your remote turn on wire on your amp?
Duane...
If you think you're confused, imagine how you feel.   1995 Subaru Legacy amp install -- posted image.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
