1998 S10 radio
tjd51
Posted: October 01, 2003 at 1:53 PM / IP Logged
The after market in-dash radio gets very warm.  Have checked the wiring harness diagram but the colors don't match.  The AM/FM works fine but not the CD player.  Have tried another radio and get the same results.  Constant 12 volts and switched 12 volts are present and the ground ohms out to the chassis.  Anyone have a similar problem?
Jay86
Member - Posts: 7
Posted: October 01, 2003 at 2:00 PM / IP Logged
Do you have a wiring kit for it or did you just hook it straight uo to your truck?
If at first you dont succeed, change the rules so that you did.
tjd51
Posted: October 01, 2003 at 2:13 PM / IP Logged
I used a harness.
tjd51
Posted: October 01, 2003 at 2:15 PM / IP Logged
That is, I used a wiring kit.
Jay86
Member - Posts: 7
Posted: October 01, 2003 at 2:31 PM / IP Logged
Hmm, If it isn, t a bad connerction off of that then I cant, help you. Sorry. By the way if you happen to know anything about where the remote connects to from the amp, please answer one of my forums. Thanks, and sorry again.
Ketel22
Silver - Posts: 976
Posted: October 01, 2003 at 7:04 PM / IP Logged
i currently have the same problem with my aftermarket hu in my 2002 altima.  just another question what are the impedences of the stock speakers, or did you replace them?
Quad L Handyman services
kenmci
Copper - Posts: 161
Posted: October 01, 2003 at 11:20 PM / IP Logged
how does the CD player not work, if there is no sound output and you have either a factory amp or and aftermarket amp, check to make sure that you have the power control/remote turn on hooked up correctly to either the factory amp or to the remote turn on for your amp.  If you hook up the power antenna wire to either of these then you will only have sound when you are on AM/FM.  Just a thought.
Ketel22
Silver - Posts: 976
Posted: October 01, 2003 at 11:24 PM / IP Logged
i dont know about his but mines just heats up and then refueses to play cds after like 2mins of play and then it will only play radio till i cool off the head unit with the ac
tjd51
Posted: October 03, 2003 at 7:03 AM / IP Logged
I took the head back to the dealer, he checked it and it was defective.  Swapped it for another one and all is OK.  Thanks for all the help.......some good ideas.
noob
Copper - Posts: 92
Posted: October 03, 2003 at 11:49 AM / IP Logged
yea my head unit kinda seems to get hot sometimes too......it could just be heat escaping from my air vents but i dunno.......i had to wire my unit right to my car.....could this cause a problem???.....everything works great other than a lil warmth
Wednesday, August 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
