2001 Dodge Intrepid Wiring
rzombie
Posted: October 02, 2003 at 1:49 PM / IP Logged
I'm having trouble locating some wires. First is the door pin wire. Second is the door lock switch wire. Thrid is the ignition wire that turns the car over.  Can anyone help me?
floaterr
Silver - Posts: 383
Posted: October 02, 2003 at 2:32 PM / IP Logged
Search. I found several posting on topic
rzombie
Posted: October 02, 2003 at 2:40 PM / IP Logged
Found nothing except for 00 dodge intrepid still doesnt help with the location
floaterr
Silver - Posts: 383
Posted: October 02, 2003 at 2:57 PM / IP Logged
Looks like you tap into the domelight for a door trigger. 2000-2002 say yellow at fuse panel
locks look to be in the hole behind kick panel.
#217 refers to relay hookup.
The "starter" wire is the one that "turns over the engine". Funny the car only uses 1 ign wire.
Good Luck!
Make:   Dodge
Model: Intrepid
Year:    2001
This Database Was Last Updated On:    10/7/02
Index #: 2404
Alarm
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE/WHITE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) AT EITHER KICK PANEL OR BCM *
Trunk Pin Switch TAN/BLACK (-) 22 PIN CONNECTOR HIGH IN DRIVER KICK
Parking Lamp BLACK / YELLOW (+) AT BODY CONTROL MODULE *
Power Lock WHITE/ D GREEN 16 PIN CONN. IN ACCESS HOLE #217**
Power Unlock SINGEL WIRE SYSTEM IN DRIVER KICK OR HIGH IN DR. KICK
* Body Control Module (BCM) Located Behind Fuse Box. #217- See Single Wire Resistor Door Lock System Diagram. **Door Locks Require +12v Pulse Thru 2.7K Ohm Resistor For Lock And +12V Pulse Thru 620 Ohm Resistor For Unlock.
Tach Signal SEE NOTE * AT POWERTRAIN CONTROL MODULE #239
Ignition #2 D GREEN/ RED IGNITION SWITCH HARNESS
Ignition #3 BLACK/ ORANGE IGNITION SWITCH HARNESS
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety BLK/WHT OR BRN/YEL (-) AT SWITCH ON TRANSMISSION OR PCM *
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDEL
Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Independant Coil System, TAN/PINK, TAN/L GREEN, TAN/L BLUE, TAN/RED, TAN/ORANGE, & TAN/D GREEN. Each Wire Is A Single Cylinder Signal. Powertrain Control Module (PCM) Loacted On Driver Side Front Fender Near Power Distrabution Block. #239 - See Immobilizer Bypass Diagram
rzombie
Posted: October 02, 2003 at 4:08 PM / IP Logged
thank you
