Whine problems
Quick
Member - Posts: 17
Posted: July 15, 2002 at 9:37 AM / IP Logged
Here are my components (all used but in great shape):
Clarion ARX6470 Deck
Clarion Rdc634 6 Disc ChangerClarion
Clarion Eqs750 Equalizer
(1) Eclipse 3520 2/1 Amplifier for front spkrs
(1) Eclipse 3525 2/1 Amplifier for rear spkrs
(1) MBAcoustics 600w 2/1 Amplifier for (2) subs
The deck is ran to the Eq and both Eclipse amps are run from eq. The sub amp is run direct from deck to amp. I have rca inline ground loop isolators on the jacks from the deckto eq input and a noise isolator on the power amp wire which is run from the battery. With the engine off i have no noise, with it on you cannot hear the stereo for the whine.HELP!! If you need other details let me know.
Platinum - Posts: 12,488
Posted: July 15, 2002 at 9:51 AM / IP Logged
  • Run all RCA cables on opposite side of the power wires and speaker wires.
  • make sure that your alternator is in good working condition. If the alternator is not powering all the connections properly you will get a whine
  • Make sure that you have a solid , clean ( paint free ) ground. Watch out that you do not ground on a panel or sheet metal. Try to ground it to the frame of the car/
  • Make sure you are using at LEAST 4 gauge power wire and 4 gauge ground wire for your system
  • Post your results
Quick
Member - Posts: 17
Posted: July 15, 2002 at 9:54 AM / IP Logged
Thanks for the quick reply...Ill post results soon
Quick
Member - Posts: 17
Posted: July 15, 2002 at 4:26 PM / IP Logged
 ok Jeff check it out:
I pulled everything out (EVERYTHING) and connected front and rear spkrs direct from head unit and used the MBAcoustic amp to the subs out of the head unit rca jacks....and i still have whine.very low but it is still there...now my question is this..My head unit is grounded to the metal casing it fits in in the dash...should this be grounded to the frame also and is it acceptable to run one heavy gauge ground from the frame and bring all the component grounds to this....Thanks again for your help.
mobiletoys2002
Gold - Posts: 1,050
Posted: July 15, 2002 at 8:45 PM / IP Logged
run the radio ground to the chasis metal and that may solve that problem. your question on multiple amp wiring, well the best way is get a ground block and run one 4 guage wire to ground keeping this short as possible. Now take an 8 guage from each of your amps and run it in to the block also as short as posible. also when grounding anything scrape the paint off the spot where you will be grounding make nice and shiny you can use a flat screwdriver and a piece of sanpaper to do this.
Posted: July 16, 2002 at 12:45 AM / IP Logged
What do you have the sub amp gains at ?? If the gains are maxed out, then turn it down to about 3/4 and listen for any hum. Check to make sure that your RCA input for the amp is not near a power source or the insulation is cracked.
Quick
Member - Posts: 17
Posted: July 17, 2002 at 6:31 PM / IP Logged
i turned the ampgains down and now have no hum...but im gonig to start putting components back in until i find whats causing it..thx again
Big Dog
Gold - Posts: 1,265
Posted: July 18, 2002 at 2:17 PM / IP Logged
Hey Quick,
You think you've got whine problems?  I have two daughters!  Man talk about whine!!!!!! Whine problems -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted: July 19, 2002 at 12:13 AM / IP Logged
OUCH !! 3 women in one household !! OUCH !! Whine problems -- posted image.
Sound Pressure
Silver - Posts: 711
Posted: July 19, 2002 at 1:51 AM / IP Logged
I feel your pain Big Dog.
Hey Jeff you think that maybe cheap RCA's might be a problem. I had a similar problem when trying to use cheap RCA's.
Sound Pressure
