envoy 2002 alarm
babaface
Member - Posts: 7
Posted: October 03, 2003 at 5:18 PM / IP Logged
does the alarm system on the envoy 2002 control the pcm for it not to send any power to the starter and or the fuel system if it does how can i cancel the alarm system permanently. my problem is i am not getting a negetive feed out of the pcm to the starter relay in the fuse box under hood.
any help is apreciated.
Platinum - Posts: 12,488
Posted: October 03, 2003 at 7:27 PM / IP Logged
You have a OEM alarm disarm wire that needs to see a (-) pulse ( lt. green@driver door module in door  )
babaface
Member - Posts: 7
Posted: October 04, 2003 at 10:39 PM / IP Logged
on my envoy 2002 that i juat got i have just confirmed the module in the driver's door is defective it does not respond to any thing locks or other and also am not able to disable the alarm with (-) puls on green wire or with key
where else i can give a puls to disable alarm i went to the passenger door module and it does not have the same colors (need to start the car )help please
RufNUSD
Copper - Posts: 184
Posted: October 04, 2003 at 11:39 PM / IP Logged
So if your unit is devo why not get it replaced and stop band aiding? If my car has a hole in its gas tank Im not going to carry around gas cans hoping it gets better.
Someone pass me that bottle.
babaface
Member - Posts: 7
Posted: October 05, 2003 at 8:34 PM / IP Logged
i needed the car for the weekend and since there is no parts availabe on weekends i thought i could ask for some experinced people for any idea .
but thanks to an idot like you who likes to make idiotic comments RufNUSD instead you should butt out of thing you dont know.
and when you ever get stuck with a hole in your gas tank on a weekend good for you dont drive till its monday and only then go to fix it but some of us will try do something before its monday.
thanks for you comment.
