help with a 740 volvo
tom cat
Member - Posts: 30
Posted: October 06, 2003 at 9:01 AM / IP Logged
need a wiring information on a volvo 740 1990. is there a problem with remote start avital 3000 or do thease cars don"t have acc line
tom cat
defective
Silver - Posts: 642
Posted: October 07, 2003 at 10:10 AM / IP Logged
Heres info for the 1985-92 Volvo 740
12v+ - red and red - ignition harness
Ignition(switched) - blue/red or red - Ignition harness
Second Ignition(switched) - black - ignition harness
Starter - Pink - ignition harness
Dome lights - black or BROWN / black(-) - at pin switch
Parking lights - white(+) - light switch or fusebox
no power locks, needs actuators
OEM Horn - yellow and blue/black(-) - Steering column harness
Head lights - yellow/white(+) - headlight switch
Tach Wire - RED / white - dash Tach or at coil pack
Accessory - blue / YELLOW - Ignition harness
Brake light - yellow(+) - brake pedal switch
Reverse Light - black(+) - at switch
Hope this helps, have fun
