No Unlock
scelsi14
Member - Posts: 26
Posted: July 16, 2002 at 9:35 PM / IP Logged
Ok, I got my relay to work for my keyless locks (thanks a lot mobiletoys2002) except now it will lock, but not unlock.  The reciever clicks and i get a reading from the unlock wires to where they attach to the actuator wires.  Could the wires on the actuator be bad? or should I look at something else?
Thanks for looking
dan768
Copper - Posts: 49
Posted: July 16, 2002 at 10:30 PM / IP Logged
Did you add aftermarket 2 wire actuators?You need 2 relays to control them,1 for the lock & 1 for the unlock.You can see if your actuator is working properly by taking your drill battery(no more then 12 volts)and touching the two wires of the actuator to each side of terminal,and then reversing them to see the actuator move the opposite way.
dan
Remember (there are no hard cars,some just take longer to install on then others)
scelsi14
Member - Posts: 26
Posted: July 17, 2002 at 7:46 AM / IP Logged
Yeah, they're 2 wire actuators but the package that I got says I don't need anything else.  When I reverse the wires it unlocks, but by pushing the Lock button on the remote.  Then reciever still clicks like it's trying to lock when I push the unlock button.
dan768
Copper - Posts: 49
Posted: July 17, 2002 at 8:11 AM / IP Logged
If you have aftermarket 2 wire actuators,you need them wired like this
No Unlock - Last Post -- posted image.
You need a relay for the lock and one for the unlock.
dan
cpgoose
Gold - Posts: 1,098
Posted: July 17, 2002 at 8:21 AM / IP Logged
"Yeah, they're 2 wire actuators but the package that I got says I don't need anything else"
The package for the actuators might  say that, but it won't know what type of keyless entry or alarm you have.  Like dan said, you will most likely need the 2 relays, unless your keyless entry has the relays built in (the manual should say if it does or not).  One problem I had when I hooked up my actuators was that my relays weren't grounded well enough, and it only opened the locks, not locked.  When I grounded it correctly, they worked both ways just fine.
scelsi14
Member - Posts: 26
Posted: July 17, 2002 at 8:31 AM / IP Logged
It has the relays built in.
That's what it says on the manual
I'll try fixing the grounding, thanks
scelsi14
Member - Posts: 26
Posted: July 18, 2002 at 2:25 PM / IP Logged
Ok, I tried grounding in several different ways and still no luck.
What would you suggest for the best type? all wires together, all wires seperated? there's 3 ground wires
I still can't figure out what would cause it to do one and not the other, does anyone else have any suggestions?
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
