installing headunit, the dimmer wire?
crudeau
Copper - Posts: 150
Posted: October 14, 2003 at 11:30 AM / IP Logged
Why, in all the cars I have installed head units in,  Does the dash light fuse blow?  Whenever I hook  up the dimmer wire on the radio harness to the headunits dimmer wire, the fuse always blows.  I have gone through probably about 20 different installations no and always end up just not connecting the dimmer wire.  Am I suppose to be using a diode or something here?
Ketel22
Silver - Posts: 976
Posted: October 15, 2003 at 2:55 AM / IP Logged
what are you doing with the illumination wire? most times i use that instead of the dimmer wire
Quad L Handyman services
italnpimp59
Silver - Posts: 427
Posted: October 15, 2003 at 8:16 PM / IP Logged
just dont hook up any orange wires!  thats the best way to avoid the problem, they dont really do much, just dim the radio a little bit when the headlights are on, not pratical at all.
Sound World
Member - Posts: 20
Posted: October 15, 2003 at 10:12 PM / IP Logged
Either don't hook up the illumination wire on the deck like they said, or use the illumination wire instead of a dimmer wire on the wiring harness.  Like pimp59 said all it does is dim the backlighting a bit when the light are turned on.  Unless it's some older Eclipse decks, those you need an illumination wire or the backlighting won't come on at all.  But it has to be an illumination wire or a wire that only shows +12v when the parking light are on, and doesn't change when you adjust the dimmer control.  Dimmer wires usually vary in voltage and polarity when adjusting the factory dimmer control, which will cause issues, in your case blowing fuses instead of frying switches.
skahide
Member - Posts: 27
Posted: October 15, 2003 at 10:37 PM / IP Logged
I just installed a KENWOOD into my 2001 Ford Escape and i used all the wires from the stock harness but the power attenna (which i dont have) and the illumination wires were left on my KENWOOD wire harness. How do i get the HU to dim? i live in the country so when im away from town lights i can really notice the backlight in the HU. How do i fix this? ANY help is needed.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
