2003 Tacoma Power Lock Wires (Colors)
rocketeer928
Posted: October 19, 2003 at 6:16 AM / IP Logged
I have a 2003 Tacoma with power locks. I want to install a Pop & Lock PL8510 power tailgate lock. The instructions, which I suspect were written in 1995, tell me to look for the BLUE/WHITE and BLACK / YELLOW striped power lock wires leading into the driver side door to make the connection. I see a BLUE/WHITE striped wire, but no BLACK / YELLOW striped wire. I even took out the power lock and window console on the door to see if I was missing something, but still no BLACK / YELLOW striped wire. I want to do the job correctly the first time, so does anyone know exactly which wires control the power locks on the 2003 Tacoma?
rocketeer928
daniel2002p
Silver - Posts: 524
Posted: October 19, 2003 at 7:24 AM / IP Logged
I have done one of those a while back and here is the setup.  To lock all the doors it is blue/white and unlock is a straight blue.  They will be in the 12pin plug in the DKP (driver kick panel).  Hope this helps.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Wednesday, January 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
