mounting shock sensors
sroth140
Silver - Posts: 513
Posted: October 19, 2003 at 10:36 PM / IP Logged
what is the preferred method of mounting shock sensors for alarms?  i just installed a black widow 4150 on an 84 caprice and it wounld only pick up shocks from the pillar behind the front seats.  the sensativity was all the way up too.  should the shock sensor be mounted to the chasis or bundled with a branch of wiring?  i could rock the car and kick the tires with out triggering the alarm, but if you kocked the pillars at all it would instant trigger.  it would warn on some windshield knocks but not trigger.
auex
Platinum - Posts: 5,041
Posted: October 19, 2003 at 10:44 PM / IP Logged
First rocking the car will not set off a shock sensor ( shock=impact). I mount shock sensors to a stiff wire bundle. There are also shock sensors that are meant to be mounted to the chassis.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
sroth140
Silver - Posts: 513
Posted: October 19, 2003 at 11:42 PM / IP Logged
good call.  ill have to play around with it with the vehicle comes back in.  the instant trigger for the doors/hood/trunk areny hooked up.  the pin switches in the doors are corroded out and he wants to add a mercury switch to the trunk.  ill be able to play with the shock sensor and see if what you guys recommend will help.
HamiltonAudio
Silver - Posts: 278
Posted: October 20, 2003 at 7:12 AM / IP Logged
I've always tied shock sensors to the main ignition harness with a large tie wrap.  This has always given me the best results, and allows some flexibility with mounting.
b
