No Remote Wire
Villa05
Member - Posts: 8
Posted: July 18, 2002 at 4:47 PM / IP Logged
i installed my amp to the bck of my sony deck without a remote wire. i just used the antenna wire and it works with the radio, but not with the CD or other featutres. have no idea what happend to the remote wire. Didn't comw w/ one or was yanked out, I DONT KNOW!! How can i fix this problem?
the12volt
Administrator - Posts: 3,959
Posted: July 18, 2002 at 4:52 PM / IP Logged
Hi Villa05, if you can give me the model number, I can probably tell which pin the remote turn on lead should be in and if need be you can move the antenna remote from it's current location to the remote location in the connector. In the meantime, you can use an accessory lead (or tie into the red wire on your radio) to supply 12V+ to your amplifier's remote turn on lead.
the12volt
Villa05
Member - Posts: 8
Posted: July 18, 2002 at 5:02 PM / IP Logged
where can i find an accesory lead. and if i tie into the red wire, wouldn't that leave the amp on all the time. and if i do tie into the red wire, is it safe?
Villa05
Member - Posts: 8
Posted: July 18, 2002 at 5:10 PM / IP Logged
the model # is CDX-CA6508
the12volt
Posted: July 18, 2002 at 5:11 PM / IP Logged
Assuming you have the radio coming on with the key, the amplifier will only come on when the key is on and yes it is safe, but like I mentioned earlier, if you can give me the model number, I may be able to tell you which pin in the radio's connector is for the remote turn on lead.
If you only have one blank pin in the connector, simply remove the power antenna remote lead from it's current pin location and insert it into the blank pin location.
the12volt
Villa05
Member - Posts: 8
Posted: July 18, 2002 at 5:31 PM / IP Logged
the model # is CDX-CA6508 Sony Xplod
TheRapture
Copper - Posts: 208
Posted: July 19, 2002 at 8:06 AM / IP Logged
you can always put a switch from constant 12v to the remote... but before you get out of the car remember to turn the switch off!!!!! haaaaaaaahahaa
mobiletoys2002
Gold - Posts: 1,050
Posted: July 19, 2002 at 12:15 PM / IP Logged
just connect the amps remote laed to a switch and connect the other side of the switch to an ignition lead in the car that way when you shut off the car it will turn off even if you forget about the switch.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
