door lock 3 pin connector
sbriar
Member - Posts: 9
Posted: October 26, 2003 at 1:16 AM / IP Logged
I am installing a keyless entry-remote start on a 96 chevy lumina, on the three pin connector  for the door lock I have the two lock and unlock wires connected, but my instructions do not show me where to hook up the third wire (red 12V+ Out), can anyone help me out?
Thanks, Steve
dangtong3
Posted: October 26, 2003 at 11:15 AM / IP Logged
 The third wire is usually fo the relay. You only need this wire if you have positive door lock type, reverse, vacumm...etc that need to be connect to a relay(s). IF you have standard negative door lock type, you only need the lock and unlock wires.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
