Volvo s40 alarm system Wiring diagram
james840a
Posted: October 26, 2003 at 9:17 PM / IP Logged
Im needing some info on the color code/wiring diagram for the main keyless/alarm unit. I am trying to install a paging unit in with the stock alarm system. But need to know the lock/unlock wires the door/hood/trunk pin trigger wires. Thanks for any help
James
AutoObsessions
Member - Posts: 26
Posted: October 28, 2003 at 10:15 PM / IP Logged
well first off the anti theft module is in the center console. All your lock wires and motors wires are there as well as all your triggers.
Lock - pink/black
unlock - brown
lock motor - gray/white
unlock motor - GREEN/ gray
Door triggers which there are 4 of. They all must be diode isolated
Drivers door - green      RR door - GREEN / WHITE
Passengers door - GREEN/ orange LR door - GREEN/ red
Trunk trigger - blue/brown
the factory alarm arm and disarm wires are the same as the lock unlock wires. Good Luck!!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
