How to properly read a tach signal
Illuminatrix
Member - Posts: 23
Posted: October 27, 2003 at 11:43 PM / IP Logged
Can someone tell me how to read the tach signal properlly.  My Tester has 200mv and 500mv in AC mode.  What should my tach wire read ?? and does voltage go up or down with a rev of engine ??
Thanks again.  I am destined not to use voltage mode.
Cheers
Travis
NowYaKnow
Gold - Posts: 1,217
Posted: October 28, 2003 at 5:00 AM / IP Logged
Here's how I read tach wires..Take your meter. Put one side to ground and the other side to your tach wire. Set your meter to AC Volts and start the car. The wire shouldn't read anything with the car off, and then just up to like 1 - 1.5 volts with the car running. When you rev up the car it should jump to around 2 - 3 volts. That's how I read all my tach wires. The exact voltage numbers aren't too important you just want to see some AC voltage that rises when you rev it. Depending on the car they all read a little differently so yours may sit at like .5 volt and rise to 1 volt or may sit at around 2.5 volts and rise to 3 there's really no set numbers. As for finding the tach wire normally you would follow the spark plug wires back to the coil packs and it will be one of the wires coming off of that module. Sometimes accessing that isn't possible though so you may have to look elsewhere..Good luck,
Mike
Illuminatrix
Member - Posts: 23
Posted: October 28, 2003 at 8:10 AM / IP Logged
So if my tester has 200mv and 500mv settings for AC what would it read.  Sorry for such a dumb question I just want to be sure.
Travis
sid2k
Member - Posts: 6
Posted: October 28, 2003 at 8:15 AM / IP Logged
200mv
Illuminatrix
Member - Posts: 23
Posted: October 28, 2003 at 9:03 AM / IP Logged
Ok I am dumb so at 200mv what should my tach wire read ????
Thanks, I want to get this dang thing set up properly.
Cheers
Travis
derek123
Copper - Posts: 163
Posted: October 28, 2003 at 11:21 AM / IP Logged
You may end up blowing that meter.
some tach signals are higher than 12 volts.
are you sure its 500 mV ?
from what your saying even a poor tach siganl ( less than one volt) is going to be too much for your meter.
also, NowYaKnow pretty much nailed it on how to test with a DMM, one thing missing is that some true tach references will keep the same voltage ( as RPM increases) but the frequency of the siganl increases instead. you need a pretty spiffy meter to read that though.
Illuminatrix
Member - Posts: 23
Posted: October 28, 2003 at 1:03 PM / IP Logged
Will a DC 12 Volt battery test on my meter work to test this signal.
Thursday, January 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
