Power Door Locks, relay related
gabe8496
Member - Posts: 19
Posted: October 30, 2003 at 2:18 PM / IP Logged
I'm looking into several systems and I notice some say that they include relays for the power door locks and some just say (+/-), which I assume that it means they connect directly without relays.
Are relays for power door locks necessary? If so, why? What kind of prevention?
-Gabe
jrilla
Gold - Posts: 1,498
Posted: October 30, 2003 at 2:39 PM / IP Logged
The systems that say (+/-) only have positive and negative outputs. So with this type of system, if your vehicle has reverse polarity door locks, then you would still need relays. Some systems only have low current negative outputs designed only to trigger relays, and a few systems come with standard relays onboard to cover all types of door locks.
So relays are only necessary in order to create enough current to trigger the factory door lock actuators. In some cases you are triggering the factory relays, so technically you could get away with a lower current output, but it is always wise to use relays.
J Rilla
Owner/Installer
gabe8496
Member - Posts: 19
Posted: October 30, 2003 at 3:15 PM / IP Logged
Sweet! Thanks for the info. I assume I could just get the basic relays they sell in autoparts store? I'm not sure if they require a certain type of relay?
-Gabe
jrilla
Gold - Posts: 1,498
Posted: October 30, 2003 at 3:25 PM / IP Logged
What vehicle do you have?
You need a Standard 30 Amp Automotive relay (SPDT)
J Rilla
Owner/Installer
gabe8496
Member - Posts: 19
Posted: October 30, 2003 at 4:01 PM / IP Logged
This is for a '96 mustang
-Gabe
jrilla
Gold - Posts: 1,498
Posted: October 30, 2003 at 4:22 PM / IP Logged
POWER LOCK is pink / YELLOW
POWER UNLOCK is pink/green
Found in either kick panel
negative w/ keyless entry
5 wire reverse w/o keyless entry
See relays page on this website for a diagram
J Rilla
Owner/Installer
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
