Woofer enclosure Help
Quick
Member - Posts: 17
Posted: July 19, 2002 at 8:38 PM / IP Logged
ok I have 2 12" subs in a box..it is one box with divider ,so two enclosures..the dimensions are 4" to 8" bottom 16" tall and approx 36" long..the amp is mb acoustics 600w 2/1..in a 1992 isuzu single cab truck..now the questions:
1. is the box big enough?
2. sould the seperate enclosures be drilled( maybe a 3inch hole) between to connect?
3. should the amp be run to each speaker or parallel the spkrs and bridge the amp?
thats all for now..thx
GlassWolf
Copper - Posts: 365
Posted: July 19, 2002 at 9:49 PM / IP Logged
dimensions look fine, no need to alter the box, and if they are 4 ohm subs, in parallel would make 2 ohms, bridged would make 1 ohm, so no run them in 2 channel stereo
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Quick
Member - Posts: 17
Posted: July 20, 2002 at 7:49 AM / IP Logged
ok what about this...i have 2 clarion 3520 amps they are 90 bridged with bass boost and low pass filters...would they do a better job,  even though they are lower power?
clarion 3520  2/1 channel  x/channelflex crossover plus subsonic filter..
i realize this is a pieced together system..i'm just trying to get the best sound possible here...thx again peeps
GlassWolf
Copper - Posts: 365
Posted: July 20, 2002 at 6:02 PM / IP Logged
try it and see.
if the speakers are 4 ohms each you're in good shape. bridge the amps and run one for each sub.
see how it sounds. adjust gains accordingly.
-GlassWolf
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
