Help cd player only works w/dome light
xekution
Posted: November 03, 2003 at 6:07 PM / IP Logged
Hi. I'm pretty new to installing car audio, but I do know some of the basics. My problem is that my friends new cd player only works w/ the dome light of his car on. It's a 99 Ford Explorer btw. I did blow the fuse during the installation, but I replaced it. He says when he turns off the dome light, the sound get's staticy and the unit won't light up. Any help you can give me at this point would be greatly appreciated. Thanks.
superstreet786
Silver - Posts: 339
Posted: November 03, 2003 at 6:15 PM / IP Logged
It is most likely not connected to either the correct power wire, ground wire or illumination wire.
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
xekution
Posted: November 03, 2003 at 6:17 PM / IP Logged
i noticed two red wires w/ black stripes when doing the install. Do you think those 2 being crossed would do it?
forbidden
Platinum - Posts: 5,354
Posted: November 03, 2003 at 6:35 PM / IP Logged
Sounds as though you have hooked into the illumination wire. Check your wiring again. Does the cd retain it's memory for the clock and radio staions? If it does then you have the correct constant power lead (yellow wire on cd harness). The problem would more than likely be with the red ignition lead.
xekution
Posted: November 03, 2003 at 8:13 PM / IP Logged
my friend just told me that he just noticed that the cd player only works right when the headlights are off. When they are turned on it goes bad again.
xekution
Posted: November 03, 2003 at 8:17 PM / IP Logged
Im going to do everything in my power to fix the problem. I do have one more question though. Asuming all the wires are hooked up right...what else can be wrong w/ it? I did at one point during the install cut 2 or 3 wires at the same time..that's what caused the fuse to blow. Could that have caused all these major problems? Im going to his house tonight to try to correct the problem. Any further input yall can give me would be great.
forbidden
Posted: November 03, 2003 at 9:10 PM / IP Logged
Yes this may be a root cause of the problem, try running a new ground wire to bare metal somewhere as well.
Alpine Guy
Platinum - Posts: 2,478
Posted: November 03, 2003 at 9:30 PM / IP Logged
why did you cut wires??  whats this world comming too!! AHHHHHHHHH, companys make wire harness's for a REASON,,,.. i hate having to go in and fix mistakes at the shop when "do it yourselfers" do the old chop and twist method.  Just save $15 and get the wire harness, sheesh.
Im done, lol goodluckHelp cd player only works w/dome light -- posted image.
