03 Mercedes E-Class VSS wire location
soundinstaller
Member - Posts: 18
Posted: November 04, 2003 at 3:15 PM / IP Logged
Anyone out there know the whereabouts of a vehicle speed sense wire on a 2003 Mercedes E300?
If you have a comprehensive tech sheet, even better.
Thanx
Sound Installer
auex
Platinum - Posts: 5,041
Posted: November 07, 2003 at 8:44 PM / IP Logged
Try looking for a GREEN/ black at the radio. It should be there even if it is not that color.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
soundinstaller
Member - Posts: 18
Posted: November 08, 2003 at 1:03 PM / IP Logged
The 03 is very different than the 02.
There is only a three wire power harness and a fiber optic connection on the back of the radio.
In addition, I can't even find an accessory wire anywhere on this vehicle. I check all three fuse blocks, and the ignition harness.
Nothing "drops out" on this car when the engine is cranking.
bizarre!
Stoffe
Posted: November 17, 2003 at 8:10 AM / IP Logged
Try GREEN/ black along passenger door (floor). Often a whole bunch of them criped together with a butt connector.
I use the cig. lighter for accessory.
