96’ Pathfinder remote starter
surroundsound
Posted: November 05, 2003 at 7:07 PM / IP Logged
I recently installed a Omega Max remote starter/alarm combo on a 1996 Nissan Pathfinder. Initially the remote starter worked great but after a few times testing it the car will not start, now even when using the key. I contacted a dealer that told me the factory disable kills the power to the fuel pump which is happening now. The remote module calls for a (-) output wire to be connected from the module to the factory disarm which is located in the drivers dash. I thought I was connected into the proper wire but by the results now I doubt it. Can any experienced installer offer some help as to troubleshooting this problem?
Platinum - Posts: 12,488
Posted: November 06, 2003 at 5:41 AM / IP Logged
There is a light green wire at the OEM keyless entry module to the driver's side dash area under the steering column.
