’00 Camry Alarm Install Pointers?
Coomer
Copper - Posts: 103
Posted: November 13, 2003 at 1:05 AM / IP Logged
Hi,
My dad just got a '00 Toyota Camry with power door locks and windows but no keyless entry, and he wants me to install an alarm system in it, mainly so that he'll have keyless entry. I've installed an alarm with remote start on my '94 Celica before, and I'm aware of how to correctly and safely install an alarm using SPDT relays and diodes where needed and such. I'm curious as to whether or not anyone has any tips or pointers for the installation. Also, how hard is a basic alarm install on a '97-'01 Camry?
Also, on this thread, it says that I should use the unlock and lock wires that test when the key is in the passenger-side door, and that these wires are dark blue, and dark blue/white. I plan to do this instead of using the wires indicated here, unless anyone can suggest why I shouldn't do this.
draasch
Gold - Posts: 2,172
Posted: November 13, 2003 at 11:59 AM / IP Logged
Make:   Toyota
Model: Camry
Year:    1999-01
This Database Was Last Updated On:    6/9/03
Index #: 6791
Alarm
Constant 12 volts WHITE & WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter RED IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) 7 PIN CONNECTOR AT THE FUSE BLOCK
Trunk Pin Switch RED / YELLOW (-) AT LIGHT IN TRUNK
Parking Lamp GREEN (+) 13 PIN CONNECTOR AT THE FUSE BLOCK
Power Lock L GREEN 20 PIN WHITE CONNECTOR
Power Unlock D GREEN IN DRIVER KICK PANEL * #209
* Child Safety Lock - BLUE/RED (-) In Same Connector As Door Lock Wires Above. #209- See Child Safety Lock Diagram.
Remote Start
Tach Signal BLACK/ ORANGE AT ENGINE CONTROL MODULE * #239
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS (HEAT/AC/ECM)
Ignition #3 N/A
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light RED / BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost YELLOW /GREEN (-) REAR DEFOGGER SWITCH
* Engine Control Module Is Located Behind The Glove Box. #239 - See Immobilizer Bypass Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Coomer
Copper - Posts: 103
Posted: November 13, 2003 at 1:47 PM / IP Logged
Interesting...I've seen four different wiring colors for the door locks from a couple different sites. Anyone else have any tips or suggestions?
draasch
Gold - Posts: 2,172
Posted: November 13, 2003 at 7:49 PM / IP Logged
the info should be pretty good. test with a meter, the lock wire will show 12v. when you hit the lock button, you will lose the 12v.
Good Luck
David
Ace Security
813-376-9778
Tampa
Scott35
Silver - Posts: 258
Posted: November 13, 2003 at 7:55 PM / IP Logged
You might be able to find a factory Toyota setup on ebay for a good price. They are mostly plug up, no splicing.
Tacomacrew
youngblood
Copper - Posts: 77
Posted: November 14, 2003 at 10:54 AM / IP Logged
the most reliable and certainly the easiest SUREFIRE 100% posive, works every time, I swear to God on my life, wires to get for unlock on the Toyota camry, years (1998-2001) is...........
UNLOCK - solid blue(royal blue)
LOCK       - solid light green
These wires can be found exiting the bottom of the fuse box in an orange molex.  This molex has approximately...um..15 wires or so... never really counted them.  But you can bet your favorite pets left eye that these wires will work every time.... no need to tag any additional child safety unlock wires or the such.  I was weened on toyota alarms and I'm thoroughly familiar with them...
Coomer
Copper - Posts: 103
Posted: November 14, 2003 at 11:38 AM / IP Logged
Thanks for all of the information guys! ’00 Camry Alarm Install Pointers? -- posted image. I'll probably do the alarm install when I go home for Thanksgiving.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
