calculate volume
psych
Posted: November 13, 2003 at 8:03 AM / IP Logged
How do I calculate the volume of a fibreglass sub-woofer enclosure,which is moulded to fit in the corner of the trunk?The enclosure is gonna b fully fibreglass and moulded in.Cant use rectangle,wedge or circular formulas.How do i go about calculating the volume?
if it's too loud ur too old!!!
pureRF
Silver - Posts: 619
Posted: November 13, 2003 at 2:01 PM / IP Logged
Get a box (cardboard) and get the volume if it for about every 2 inches and then fill your glass box with packaging popcorn. take the popcorn from the glass box and put it in the cardboard box.
dream it, build it, fiberglass it
Wherm
Copper - Posts: 51
Posted: November 13, 2003 at 5:07 PM / IP Logged
if it's all fiberglass, just fill it with water.  that won't hurt it.  then fill liter bottles with that water till the box is empty.  You can easily convert liters to cubic feet, and i'm sure that conversion equation is on this website.  I've seen this process done many times, and it's the most accurate.
pureRF
Silver - Posts: 619
Posted: November 13, 2003 at 9:05 PM / IP Logged
i would not suggest getting the sub ring, which most likly is MDF (absorbs water), wet.
SoundImage
Copper - Posts: 75
Posted: November 25, 2003 at 1:29 AM / IP Logged
best way is to line the box with a heavy garbage bag then fill it with water.  That way it's accurate and you preserve the enclosure.  The only down fall you is don''t know how much volume until it's built
Wherm
Copper - Posts: 51
Posted: November 25, 2003 at 9:49 PM / IP Logged
good call with the plastic bag.
