2003 camry unlock
zillah
Posted: November 14, 2003 at 11:10 PM / IP Logged
I installed an Autopage rf-410 into a 2003 camry le with factory keless entry and trunk.
the alarm unlock (-) was attached to the (-) blue in dkp.
When the doors are remotely unlocked the drivers door will unlock, then approx 2 seconds pass and the rest of the doors will unlock... does this happen because I have not programmed the alarm for a double pulse?
I have also not connected the alarm unlock to the child safety lock wire. The color for this wire is supposed to be blue/red.. but the only blue/red I can find is for the door lock motor? Does the child safety lock wire need to be connected? if so where is it and what color?
Is there a way to get the drivers door to open on the first push of the unlock button and then the rest of the doors on the second push similar to the factory keyless entry?
Thanks.
Rod
draasch
Gold - Posts: 2,172
Posted: November 15, 2003 at 9:44 AM / IP Logged
Make:   Toyota
Model: Camry
Year:    2003
This Database Was Last Updated On:    6/9/03
Index #: 885
Alarm
Constant 12 volts WHITE/ RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW AND BLACK /WHITE AT IGNITION SWITCH HARNESS *
Dome Light GREEN/ RED (-) IGNITION KEY CYLINDER LIGHT
Trunk Pin Switch GREEN / WHITE (-) AT THEFT DETERRENT E.C.U. **
Parking Lamp GREEN (+) AT THE BACK SIDE OF E.C.M.***
Power Lock BLUE / YELLOW 13 PIN GRAY CONN. IN DR KICK
Power Unlock BLUE 20 PIN WHITE CONN.IN DR KICK ****
* There Are Two BLACK / YELLOW Wires Please Check. ** Theft Deterrent E.C.U. Is Located Behind Pass Side Dash Top Right. *** E.C.M. Located Above Drivers Kick Panel A Part Of Fuse Box. **** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. #201 - See Negative Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
NowYaKnow
Gold - Posts: 1,217
Posted: November 15, 2003 at 10:11 AM / IP Logged
"Is there a way to get the drivers door to open on the first push of the unlock button and then the rest of the doors on the second push similar to the factory keyless entry? "
Does your autopage unit have a driver door priority output? If so you'd want to use a relay on the blue/black driver door wire (have to cut it) to do the driver door first and then your unlock wire to the blue wire. Wiring in DDP also takes care of the child safety so you won't have to worry about that.
Edit: Ok I was being lazy here's how you would hook up the relay..
85 - To (-) driver door priority output
86 - 12v constant fused
87a - to switch side of cut blue/black wire
30 - to motor side of cut blue/black wire
87 - to 12v constant fused
Good luck,
Mike
