ct 3300 prostart remote
yerav
Posted: November 18, 2003 at 7:13 AM / IP Logged
 I have installed a ct 3300 prostart car remote starter on My 1995 Dodge 1500 ext. cab  pickup. All wires appear to be installed correctly but I cant seem to get the remote to program. Its supposed to flashh 5 times to signal conplete program. All I can get is 2 flashes. Any help or idea's would be appreciated.
derek123
Copper - Posts: 163
Posted: November 18, 2003 at 7:23 AM / IP Logged
when you turn the IGN on for the first time, count to 3...... then continue.
when you get ot the part about pressing the locking button 2X, just press and hold it, till you get the flashes.
mxxmikexx
Silver - Posts: 796
Posted: November 19, 2003 at 12:29 PM / IP Logged
first off, make sure the system is unlocked , next, when you turn the ignition on wait until the doorlocks try to lock (due to ignition controlled locks) then go ahead and try to enter the program mode.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
yerav
Posted: November 20, 2003 at 1:35 AM / IP Logged
Thanks for the advise. After many hrs of fustration I just kept hitting the lock button and after about 8 hits the remote finaly programed itself and the remote start now works fine.  The manual says to hit the lock button twice in 3 seconds but that did not work. So I hope this will help others.  Good Luck.   Thanks again for the help.
