what resistor with LED
rbf351
Member - Posts: 18
Posted: July 23, 2002 at 6:41 PM / IP Logged
i'm getting 120 Siemens Hyper Bright Orange LEDs. LO 5436 to use on my car
how do i know what resistor to use with it so i don't burn the LED's up? i'm not sure how may i'm going to use
Big Dog
Gold - Posts: 1,265
Posted: July 24, 2002 at 2:14 PM / IP Logged
Hey rbf351,
Not knowing what voltage the LED works at,  we'll have to guess.   If you have a selection of resistors then start with the largest value and work your way down being careful not to exagerate the current.  what resistor with LED -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
rbf351
Member - Posts: 18
Posted: July 26, 2002 at 9:50 AM / IP Logged
i found some info on the LEDS
Foward Current 30 Ma
power consumption 80 mW
hope this help, i'm new at this and have no clue what resistors to use
i have 900 resistors with the following values
  • 1/4w 1 ohm 1% - 50 pieces on tape
  • 1/4w 15 ohm 1% - 50 pieces on tape
  • 1/4w 39.2 ohm 1% - 50 pieces on tape
  • 1/4w 51.1 ohm 1% - 50 pieces on tape
  • 1/4w 562 ohm 1% - 50 pieces on tape
  • 1/4w 665 ohm 1% - 50 pieces on tape
  • 1/4w 909 ohm 1% - 50 pieces on tape
  • 1/4w 1.33k ohm 1% - 50 pieces on tape
  • 1/4w 2.49k ohm 1% - 50 pieces on tape
  • 1/4w 7.5k ohm 1% - 50 pieces on tape
  • 1/4w 15k ohm 1% - 50 pieces on tape
  • 1/4w 12.1k ohm 1% - 50 pieces on tape
  • 1/4w 4.75k ohm 1% - 50 pieces on tape
  • 1/4w 33.2k ohm 1% - 50 pieces on tape
  • 1/4w 28k ohm 1% - 50 pieces on tape
  • 1/4w 53.6k ohm 1% - 50 pieces on tape
  • 1/4w 169k ohm 1% - 50 pieces on tape
  • 1/4w 301k ohm 1% - 50 pieces on tape
  • mobiletoys2002
    Gold - Posts: 1,050
    Posted: July 26, 2002 at 9:59 AM / IP Logged
    333 ohm resistor will give you 2 volts a 300 ohm resistor will give you 3 voltswhat resistor with LED -- posted image. within 10 %of this will give those voltages
    trusdamanr
    Copper - Posts: 116
    Posted: July 30, 2002 at 12:30 PM / IP Logged
    resistance=voltage/current
    Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
