95’ toyota camry alarm/remote start
siuto
Member - Posts: 10
Posted: November 22, 2003 at 8:51 PM / IP Logged
Can anyone get me wire color and locations on a 95' camry? I'm also having trouble finding tach wire, and factory security arm/disarm wire.
Can I intall the remote starter/Alarm without using any external relay?????
siuto
Member - Posts: 10
Posted: November 22, 2003 at 11:15 PM / IP Logged
Help pls,I had a 95' Toyota Camry and wanna to intall Autostart AS6010TW alarm w/ starter, found out that there is 2 wires of constant 12 volts wire, white and WHITE/ red, I want to know which wire should I use to connect?
is that the 95' camry has 2 igniton wires???
Raid
Member - Posts: 41
Posted: November 23, 2003 at 7:21 AM / IP Logged
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1995-96&make=Toyota&model=Camry&ID=18955&type=Alarm
This is what I found on this site. There was also 2 other diagrams for the same yr/model.
Raid
Member - Posts: 41
Posted: November 23, 2003 at 7:23 AM / IP Logged
sorry I messed up on the link toyota camry
profuse007
Gold - Posts: 2,015
Posted: November 23, 2003 at 8:09 AM / IP Logged
i was manage to go without a tach and it works fine
Houston,TX
Falcon 1
Copper - Posts: 130
Posted: November 23, 2003 at 9:25 AM / IP Logged
Do the wires have constant 12v when key is off. Or when cranking?
Do it right the first time, only a doctor can bury his mistakes.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 23, 2003 at 9:45 AM / IP Logged
your remote start probably has two red wires to conect to constant power, if it does use both the 12 volt constant wires in the vehicle.
siuto
Member - Posts: 10
Posted: November 23, 2003 at 1:53 PM / IP Logged
thank you ~~~~
How about the starter kill relay??? Do I have to connect this relay
siuto
Member - Posts: 10
Posted: November 23, 2003 at 1:58 PM / IP Logged
yep my remote start has two red wires....thanks.....
mobiletoys2002
Gold - Posts: 1,050
Posted: November 23, 2003 at 3:03 PM / IP Logged
well if you want a starter kill then yes if not then no.If you connect starter kill relay then make sure that the starter output from the starer is on the side of the cut wire away from the ignition switch.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
