2003 Sierra Denali Speed Sensor
blindsighted
Posted: November 23, 2003 at 4:18 AM / IP Logged
Can any one tell me what color the speed sensor is for the 2003 Sierra denali. I just installed a Kenwood Gps system and I can't find the speed sensor wire in my truck.
Any advice is appreciated.
sparkie
Platinum - Posts: 2,061
Posted: November 23, 2003 at 3:34 PM / IP Logged
The vehicle's speed sensor wire is a dark GREEN / WHITE wire available at the instrument cluster in the cavity marked A4.
sparky
blindsighted
Posted: November 23, 2003 at 10:27 PM / IP Logged
where might I find that.
sparkie
Posted: November 24, 2003 at 8:45 PM / IP Logged
Remove the trim panel that surrounds your gauges, radio and climate controls. Pull rewards gently as it is only held in by clips. Remove the four 7mm screws holding the gauges/instrument cluster in the dash and pull the instrument cluster out of the dash. The plug is in the top of the cluster and has labels on it for the sides A and B. Pay close attention as there are two GREEN / WHITE wires in the plug, but only one in A4.
sparky
rgardjr
Member - Posts: 17
Posted: December 11, 2003 at 1:54 AM / IP Logged
Any pictures of the final results?  I've got an '03 SD that I'm building up the system on.
