1992 buick park ave remote start
lieast
Member - Posts: 6
Posted: November 23, 2003 at 3:49 PM / IP Logged
Anyone have wiring list for remote start for this car.....the VATS is already disabled...so that will make it easier.....i need to know wiring color codes to install. Any help would be appreciated. Mike
lieast
Member - Posts: 6
Posted: November 24, 2003 at 4:29 PM / IP Logged
please.....i can really use some help!
draasch
Gold - Posts: 2,172
Posted: November 24, 2003 at 4:57 PM / IP Logged
Make:   Buick
Model: Park Avenue
Year:    1989-92
This Database Was Last Updated On:    6/9/2003
Index #: 2102
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin Switch N/A
Parking Lamp BROWN (+) LIGHT SWITCH
Power Lock LIGHT BLUE DRIVER KICK PANEL #202
Power Unlock BLACK DRIVER KICK PANEL #202
#202- See Positive Pulse Door Lock Diagram
Remote Start
Tach Signal WHITE AT DISTRIBUTOR OR AT ENGINE CONTROL MODULE
Ignition #2 ORANGE IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety ORANGE / BLACK - ENGINE CONTROL MODULE OR GEAR SELECT SWITCH
Brake Light WHITE OR LIGHT BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light LIGHT GREEN GEAR SELECT SWITCH
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
