power for (2) 13.5 JL W7's
jeffchilcott
Platinum - Posts: 2,483
Posted: November 29, 2003 at 6:35 PM / IP Logged
alright guys here is the trick....power (2) JLw7's    13.5 incher's      I have a kicker xs100.....i would love to use this amp but i dont know if it will push them....the xs100 is 50x2 4 stero and by my sheets i got with the amp 1623@1ohm mono...it does have a 150amp fuse on the bad boy but not sure again if it will run them.....and i will have an awkard load 1.5 per coil...thanks.....by the way if any of the newbies start recomending that their frind has a 2000watt prestige or pyramid or garbage like that I swear i will come beat you with one oif the fresh w7's in my living room,   you should only have the blessing to be touched by such a product.     thanks for the time
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
forbidden
Platinum - Posts: 5,354
Posted: November 29, 2003 at 7:54 PM / IP Logged
Well it looks OK from a load perspective, a series parallel setup will net you approx. 1.5ohm. The problem I see is that you run the risk of underpowering the subs, a quick look at the JL Audio site shows that 500rms is on the low limits of output levels where they do not recommend use. It would appear that you are safely over that. The amp You have is a real good old school Kicker, I think it will work fine. Just make sure that amp can get the current that it requires and you should be quite happy.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
