Replace siren?
lrciii
Member - Posts: 15
Posted: July 25, 2002 at 2:43 PM / IP Logged
Greetings
Finally finished installing the alarm in my 300zx except for 1 step. The siren, I cannot find a spot big enough for the supplied horn under the hood. I noticed at Radio Shack they carry several different piezo horns, some pretty high db & would probably fit. Would they work OK? I'm not sure if all the various noises & warbles they make are built into the horn or the alarm itself.
Thanks!
Lee
www.raising-cain.com
Platinum - Posts: 12,488
Posted: July 25, 2002 at 3:10 PM / IP Logged
The sounds are built into the alarm module. Just make sure that the siren is weather resistant otherwise you'll short out the siren and matbe worse... the alarm Replace siren? -- posted image.
mobiletoys2002
Gold - Posts: 1,050
Posted: July 25, 2002 at 6:12 PM / IP Logged
be carefull on that siren wire coming through the firewall. if it shorts you are screwed and so is the brain.
