2000 Nissan Xterra wiring diagram
ReptileAudio
Posted: December 02, 2003 at 10:27 AM / IP Logged
I need the wiring diagram for a 2000 Nissan Xterra to install an alarm/remote start. I also need to know how to get past the clutch (haven't done a 5speed before).
Rob
ReptileAudio
defective
Silver - Posts: 642
Posted: December 02, 2003 at 10:52 AM / IP Logged
hmmm... that's a good one, i cant even find taht info and don't think i have ever done one.....if you w\find the answer will you keep me posted?
cdoxp800
Posted: December 07, 2003 at 12:50 PM / IP Logged
As for the clutch, I am no sure how Nissan works there sensor, but I have in the past just shorted the two wires that are on the clutch. There may be what looks to be a push button. Try shorting these and see it the car starts. Just make sure you are out of gear first.
NISSAN X-TERRA        1999-2003
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHITE/ REDIGNITION SWITCH HARNESS
IGNITION 1BLACK/ WHITEIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1REDIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2BLUEIGNITION SWITCH HARNESS
STARTER 1BLACK/ GREEN IGNITION SWITCH HARNESS
STARTER 2BLACK / YELLOWIGNITION SWITCH HARNESS
PARKING LIGHTSBLUE/RED (+)@ LIGHT SWITCH or DRIVER KICK PANEL
DOMELIGHTRED / BLACK ( - )PIN 9 OF 36 PIN CONNECTOR @ SECURITY MODULE   *1
POWER DOOR LOCKYELLOW ( - )PIN 18 of 36 PIN CONNECTOR @ SECURITY MODULE  *2
POWER DOOR UNLOCKYELLOW/RED ( - )(TYPE B) REQUIRES A DOUBLE PULSE to UNLOCK
TACH SENSORPINK/BLUE or BLACK@ INSTRUMENT CLUSTER or ECM  *3
BRAKEBROWN / RED (+)@ SWITCH ABOVE BRAKE
HORNLT. GREEN/ RED or BROWN  ( - )@ STEERING COLUMN
FACTORY DISARMYELLOW/RED (-) DISARMS with UNLOCK *4
NOTES:
*1 - On vehicles without power door locks use RED / BLACK at any door switch or also found in the driver A pillar. Vehicles with power door locks use GREEN/ RED for the driver door, GREEN/ BLACK for the front passenger door and RED / BLACK for the rear doors. All found at the SECURITY (Smart Entrance Control Unit). Use all three and diode isolate each.
*2 - The SECURITY (Smart Entrance Control Unit) is located above the hood release in the drivers kick panel. The door lock wires only meter when your turn the key in  either door key cylinder.
*3 - The ECM is located below the heater box to the right of the accelerator pedal, behind the trim panel. The tach is in the top row, 3rd pin left of center of the plug. The VSS is in the 2nd row from the top, 4th pin right of center.
*4 - A single pulse to the unlock wire will disarm the factory alarm with out unlocking the doors.
Chad
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
