Locks on 2000 Isuzu Rodeo
CarAudioPrez
Member - Posts: 20
Posted: December 05, 2003 at 8:22 AM / IP Logged
Hey I'm installing a 790XV in my 2000 isuzu rodeo. I looked at the diagram and it has 5 wires for the door locks:
Door LockLight GREEN/ Red(-) Negative Trigger Keyless Entry
Door UnlockRED / Blue (-) Driver's Kick Panel White 22 Pin Connector
Driver's LockBlue/Red (+) Driver's Kick Panel
Driver's UnlockBlue/White (+) Driver's Kick Panel
Passenger UnlockBlue (+) Driver's Kick Panel
My question is if this is the 5 wire type system or if this has the central locking system like some of the older rodeo's had. If so what will I need to connect it to the alarm. I will be using a DEI 451M also to connect the locks to the alarm.
auex
Platinum - Posts: 5,041
Posted: December 05, 2003 at 2:55 PM / IP Logged
All you need to do is hook up the -trigger door lock and unlock, the other wires are for the actual door lock motor wires.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
CarAudioPrez
Member - Posts: 20
Posted: December 05, 2003 at 3:37 PM / IP Logged
thanks for the info
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
