Alpine MRV-F340 + RFZ-3408 + 6402cfp= ?
sm951
Member - Posts: 25
Posted: December 05, 2003 at 6:22 PM / IP Logged
Hi,
I received an Rockford Fosgate 8" RFZ-3408 sub and enclosure for X-mas (early :)) and would like to get a decent amp for it.  All I want is good reliable sound - not a true audiophile yet.
I can get the Alpine 4-channel MRV-F340 amp for $225.  Is this amp good, considering that my system only consists of:
- two 4x6 Infiniti Reference 6402cfp speakers up front
- one 8" sub in a sealed enclosure in the hatch
- an older Alpine head unit with 2 sets of RCA outputs
The car is a 944 and I'm anxious to get it sounding good (when I'm not listening to the exhaust)...
Thanks for all your helpAlpine MRV-F340 + RFZ-3408  + 6402cfp= ? -- posted image.
forbidden
Platinum - Posts: 5,354
Posted: December 05, 2003 at 6:47 PM / IP Logged
It looks like a good little amp 35x4 ot 35x2 and 90x1. just enough to get you some decent sound. Not a 100% perfect match but with such a small sub and vehicle, it should sound and operate fine.
sm951
Member - Posts: 25
Posted: December 05, 2003 at 7:35 PM / IP Logged
Actually, I think these are the specs.  I hope I'm not buying the wrong amp!
  • RMS Power Output (Watts x Channels) 55 x 4
  • Frequency Response 20-20k Hz
  • THD at Rated RMS Power 0.08%
  • Signal to Noise Ratio 100 dB
  • Input Voltage 14.4v
  • Peak Power Output (Watts x Channels) 250 x 2
  • Power at 2 Ohms (Watts x Channels) 65 x 4
  • Bridged Power (Watts x Channels) 130 x 2
  • I plan to run two of the amp's channels for the front speakers and bridging the rear two channels for the sub.  Sound ok to you guys?
    forbidden
    Posted: December 05, 2003 at 7:41 PM / IP Logged
    Right choice on how to wire the amp to the speakers. Throw all the specs above out the window, you need to see a rms power rating @ 12 volts measured into 4 ohms, this is where I came up with the ratings for you, a closer look at the Alpine amp's owners manual should verify this. Still is an OK match
    sm951
    Member - Posts: 25
    Posted: December 05, 2003 at 7:53 PM / IP Logged
    forbidden wrote:
    Throw all the specs above out the window, you need to see a rms power rating @ 12 volts measured into 4 ohms, this is where I came up with the ratings for you...
    Gotcha...you're absolutely right!
    sm951
    Member - Posts: 25
    Posted: December 11, 2003 at 3:13 PM / IP Logged
    OK, you piqued my interest...
    What would be a ideal/perfect matching amp, without blowing my savings?  My car has a bit of road noise, so $400+ amps won't be necessary.
    Thanks for the help!
