1994 toy corolla DX alarm/remote start info
bdepew
Member - Posts: 6
Posted: December 07, 2003 at 1:45 PM / IP Logged
I need the wiring info for a 94 toy corolla DX..
for windows, remote start, locks, 12+ constant and switched...and radio info..
thanks
Sabre
Member - Posts: 8
Posted: December 11, 2003 at 2:00 AM / IP Logged
1994 Toyota Corolla
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/black          |-  |passenger kick              |
|     POWER UNLOCK|blue/red *1         |-  |passenger kick              |
| PARKING LIGHTS +|green               |   |dimmer switch or kick       |
| PARKING LIGHTS -|lt. green or white  |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|RED / white or black*2|-  |plug at top of fusebox      |
|  TRUNK/HATCH PIN|RED / white *3        |-  |light or pin in trunk       |
|         HOOD PIN|red                 |-  |anti-theft ECU *4           |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|black               |   |check connector             |
|      SPEED SENSE|RED / yellow          |4  |center console 22 pin plug  |
|       BRAKE WIRE|GREEN / WHITE         |+  |plug in fusebox             |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|yellow - green      |A  |in drivers door             |
|  RF WINDOW UP/DN|grn/red - blu/wht   |A  |in drivers door or DKP      |
|  LR WINDOW UP/DN|RED / grn - blu/blk   |A  |in drivers door or DKP      |
|  RR WINDOW UP/DN|RED / blk - yellow    |A  |in drivers door or DKP      |
Notes:
*1 GREEN / WHITE on models with factory alarm.  *2 Use the Black in a 2 pin connector at the top of the fusebox on versions without a sunroof.  On cars with a sunroof use the RED / white in a 4 or 6 pin connector in the same location.  When adding dome light supervision use the door trigger wire and relay isolate to keep ground from entering the fusebox side of the wire or unlock will not function properly.  *3 On the wagon version the rear door is tied in with the door trigger wire.  *4 The anti-theft ECU is located high in the drivers side kick panel.
bdepew
Member - Posts: 6
Posted: December 11, 2003 at 9:53 AM / IP Logged
thanks alot
