1987 bmw 325 keyless entry
jonny757
Posted: December 08, 2003 at 12:05 PM / IP Logged
Hi
    I would like to purchase the prestige aps 685 remote start keyless entry system for this car. Does anyone know the wire codes for this car . I found the wire codes for 1988-91 are these the same for the 1987 325 four door.
Geeque
Silver - Posts: 310
Posted: December 24, 2003 at 10:06 AM / IP Logged
Here this may help:
SecurityBattery   RED +   (+)   IGNITION SWITCH HARNESSIgnition   GRN   (+)   IGNITION SWITCH HARNESSStarter01    BLK/YEL +   (+)   IGNITION SWITCH HARNESSAllDoorTrigger   BRN/VIO (-)    (-)   DRIVER'S KICK PANEL AT DOME DELAY RELAYTrunkTrigger   BRN/BLK (-)   (-)   AT TRUNK LIGHTHoodTrigger   N/AFactoryAlarmDisarm   N/AParkingLights   GRY/YEL L   (+)   GRY/WHT R AT LIGHT SWITCHSecurityParking LightsALSO (+) GRAY/WHITE-DIODE ISOLATERemote StartBattery   RED +   (+)   IGNITION SWITCH HARNESSIgnition   GRN   (+)   IGNITION SWITCH HARNESSIgnition02    +   IGNITION SWITCH HARNESSIgnition03    +Accessory01   VIO +   (+)   IGNITION SWITCH HARNESSAccessory02   +Starter01    BLK/YEL +   (+)   IGNITION SWITCH HARNESSAntiTheftSystem   NONETach    BLK (-)   (-)   AT DIAGNOSTIC CONNECTORSpeedSense   BRN/RED   (AC)   REAR AXLEParkingLights   GRY/YEL L   (+)   GRY/WHT R AT LIGHT SWITCHBrakeLights   GRN/RED   (+)   AT BRAKE SWITCH ReverseLights   BLU/WHT   (+)   AT REVERSE LIGHT SWITCHHorn    BRN/YEL (-)   AT STEERING COLUMNDoorlocks / WindowPowerUnLock   GRN/BLU (-)   (-)   NEGATIVE TRIGGERPowerLock   YEL/BLU (-)    (-)   DRIVER'S KICK SPK "KEEP RELAYS UPRIGHT"ConvenienceHeadLights   YEL/GRN   (-)   AT LIGHT SWITCHLowSpeedWipers   BLK/RED (-)   (-)   AT WIPER SWITCH   Mobile Audio / VideoBattery   RED +   (+)   IGNITION SWITCH HARNESSAccessory01   VIO +   (+)   IGNITION SWITCH HARNESSGround   BRN -   (-)   RADIO HARNESSPowerAntenna   WHT   (+)   RADIO HARNESSFrontLeftSpeakerPos   WHTFrontLeftSpeakerNeg   BLKFrontRightSpeakerPos   WHTFrontRightSpeakerNeg   BLACKRearLeftSpeakerPos   WHTRearLeftSpeakerNeg   BLKRearRightSpeakerPos   WHTRearRightSpeakerNeg   BLKAmp   BEHIND REAR SEATControl Modules
Gary Kline
MECP Master Technician
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
