Alpine SEC100/150
fuzzyinc
Posted: July 27, 2002 at 9:49 AM / IP Logged
Does anyone have the install digram that came with eather one of these models? Alpine SEC100/150
Circuit City did not give me one and trying to work on the system w/o that is kinda hard!
thanks
Platinum - Posts: 12,488
Posted: July 27, 2002 at 9:57 AM / IP Logged
What do you mean they didn't give you one ?? Alpine had the installation instructions and wiring diagram as part of a NEW SEALED package. If they didn't have one packaged in the box, chances are you have a refurbished or B stock merchandise. Regardless, here is the wiring diagram for the alarm:
http://www.velocitymotorsport.com/Alpine_150R.jpg
fuzzyinc
Posted: July 27, 2002 at 10:24 AM / IP Logged
Thanks Alot for this ! just a wonder i have read that you have done alot of installs with alpine alarms, mine seems quite and not as load as others also the range on it is very short, is this a common problem with alpines? are there any quick fix's?
Posted: July 27, 2002 at 11:09 PM / IP Logged
The Alpine siren is a soft chirp type siren where it will not be very loud when you arm/disarm the system, but when you let the system go off, it will get louder as you let it continue it's full panic cycle. The range on ALL Alpine alarms suck !! If your lucky you'll get 50 - 75 feet, realistically you will get about 30 - 50 feet.
