dodge caravan 2001 resistor
AznGuyz
Posted: December 11, 2003 at 7:15 PM / IP Logged
hi there i'm new here so can anyone help me ?
for the parking light  which resistor is correct 5600 ohm or 2.1k ohm ? cuz i found on some other website is said 5600 ohm
sparkie
Platinum - Posts: 2,061
Posted: December 11, 2003 at 7:19 PM / IP Logged
Use a 5,600 ohm resistor through ground to trun on the parking lights.
sparky
AznGuyz
Posted: December 11, 2003 at 7:21 PM / IP Logged
thank you very much
extreme1
Silver - Posts: 1,070
Posted: December 11, 2003 at 10:12 PM / IP Logged
2.1k ohm resister to ground, WHITE/ brown wire at ignition switch, wire rests at ground, must use relay, term 87 ground (2.1k resistor), term 87a switch side, term 30 BCM side.
extreme1
Posted: December 11, 2003 at 10:13 PM / IP Logged
2.1k ohm resister to ground, WHITE/ brown wire at headlight switch, wire rests at ground, must use relay, term 87 ground (2.1k resistor), term 87a switch side, term 30 BCM side.
