Door Trigger - 97 Grand Prix
jhellemn
Member - Posts: 6
Posted: December 13, 2003 at 9:54 AM / IP Logged
We are working on a 1997 Pontiac Grand Prix.  The car is supercharged.  It has the electronic display in the dash that indicates when a door is open.  It will display any one of the four doors.  It has the delay fade off dome light.  Where is the most convenient place in this car to pick up a door trigger?  Is there a whre from the electronic display to the dome light that I can use as a trigger?  Any help is greatly appreciated!
John Hellemn
Geeque
Silver - Posts: 310
Posted: December 13, 2003 at 10:16 AM / IP Logged
Use the white wire at any interior light, make sure you diode isolate the wire or you'll encounter problems, gray stripe on diode towards alarm.
Gary Kline
MECP Master Technician
draasch
Gold - Posts: 2,172
Posted: December 13, 2003 at 10:46 AM / IP Logged
Dome Light TAN (DR) & D BLUE (ALL OTHER DOORS) (-) AT BCM **
** TAN (-) Wire Covers Driver Door Only, D BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. *** Body Control Module (BCM) Located Behind Driver Dash To Left Of Steering Column.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
