2003 olds aurora color and location chart
misterjimbo
Silver - Posts: 535
Posted: December 17, 2003 at 5:17 PM / IP Logged
i need the wire color/location chart for a 2003 olds aurora. i have the audiovox tech sheet but it is never correct.
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 5:19 PM / IP Logged
What do u need exactly? Which wires and locations?
Gary Kline
MECP Master Technician
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 5:24 PM / IP Logged
See if this helps, its 2002 but it shouldnt have changed too much.
SecurityBattery ORG OR ORG/BL  (+) IGNITION SWITCH HARNESSIgnition  PNK  (+) IGNITION SWITCH HARNESSStarter01 VIO/YEL +  (+) IGNITION SWITCH HARNESSAllDoorTrigger TAN (-) (-)  AT MODULE IN DRIVERS DOORFrontLeftDoorTrigger  TAN  -  DRIVERS DOOR  MOD.FrontRightDoorTrigger  DK BLU  -  RESPECTIVE DOOR MOD.RearLeftDoorTrigger DK BLU  -RearRightDoorTrigger DK BLU  -  RESPECTIVE DOOR MOD.TrunkTrigger BLK -  (-)  RIM MOD, REAR SEAT,UPPER CORN, DRVS SIDEFactoryAlarmDisarm LT.GRN - DRIVERS DOOR MOD, SPEAK DRIVERS SIDEFactoryAlarmArm  TAN (-) PULSE BOTH TAN WIRES AT MODULE DRVRS DOOParkingLights  BRN  (+) DO NOT USERemote StartBattery ORG OR ORG/BL  (+) IGNITION SWITCH HARNESSIgnition  PNK  (+) IGNITION SWITCH HARNESSIgnition02  WHT +  (+) IGNITION SWITCH HARNESSIgnition03 +Accessory01 ORG +  (+) IGNITION SWITCH HARNESSAccessory02   +Starter01 VIO/YEL +  (+) IGNITION SWITCH HARNESSAntiTheftType  RF ACTIVATED SYS.AntiTheftSystem  PASSKEY IIIKeySense  LT.GRN  (-)  (-)  IGN SWITCH HARNESSTach  WHT/VIO  (-)  IGN COIL ON TOP OF MOTORSpeedSense DK GRN/WHT CRUISE CTRL MOD,UNDER HOOD,CNTR FIREWALL ParkingLights  BRN  (+) DO NOT USEBrakeLights WHT +  (+) LOW IN DRIVERS KICK ReverseLights LT.GRN  (+) (+) LAMP CONTROL MOD.Horn  BLK - DIM MOD, NEAR PASS KICK, 3 CONN EXIT OUT Doorlocks / WindowPowerUnLock  ORG/BLK - (-)  DRIVERS DOOR LOCK SWITCHPowerLock  RED / BLK -  (-)  DRIVERS DOOR LOCK SWITCHDriverDoorMotor01 TAN DRI (+) LEFT STEERING COLUMNDriverDoorMotor02 GRY (+) DRIVERS DOOR MOD, SPEAK, DRVS SIDEPassengerDoorMotor01  TAN PASS DOOR MOD,SPEAK PASS DOORLeftFrontWindow01 DK BLU  REVLeftFrontWindow02 BRN  REV  DRIVERS DOOR MOD,ABOVE SPEAK, DRVS SIDERightFrontWindow01  DK BLU  REV  PASS DOOR LCK MOD,ABOVE SPEAK, PASS SIDERightFrontWindow02  BRN  REV  PASS DOOR LCK MOD,ABOVE SPEAK, PASS SIDELeftRearWindow01 DK BLU  REV  LR DOOR MODLeftRearWindow02 BRN  REV  LR DOOR MODRightRearWindow01 DK BLU  REV  RR DOOR MODRightRearWindow02 BRN  REV  RR DOOR MODSunRoofMotor01 DK GRN REV  SUNROOF MOTOR, TOP CNTR, REAR WINDSunRoofMotor02 LT GRN  REV  SUNROOF MOTOR, TOP CNTR, REAR WINDConvenienceHeadLights  WHT - (+) DIM MOD,PASS KICK,3 CONN. EXIT OUTLowSpeedWipers  WHT + DIM MOD,PASS KICK,3 CONN. EXIT OUTTrunkRelease  LT. BLU -  (-)  RIM MOD,BEHIND REAR SEAT,UPPER CORN DVRSMobile Audio / VideoBattery ORG OR ORG/BL  (+) IGNITION SWITCH HARNESSAccessory01 ORG +  (+) IGNITION SWITCH HARNESSGround  BLK/WHT - (-)  RADIO HARNESSIllumination  GRY/BLK  (+) RADIO HARNESSDimmer BRN/WHT  (+) RADIO HARNESSPowerAntenna  DK.GRN (+) RADIO HARNESSFrontLeftSpeakerPos  TANFrontLeftSpeakerNeg  GRYFrontRightSpeakerPos  LT.GRNFrontRightSpeakerNeg DARK GREENRearLeftSpeakerPos BRNRearLeftSpeakerNeg  YELRearRightSpeakerPos  DK.BLURearRightSpeakerNeg  LT.BLUControl Modules
Gary Kline
misterjimbo
Silver - Posts: 535
Posted: December 17, 2003 at 6:16 PM / IP Logged
for keyless remote start. audiovox has 3 ignition wires, cant remember what they were i left the tech sheet at work
