1990 Honda Civic, Viper ESP500
pimpcivic
Posted: December 20, 2003 at 2:24 PM / IP Logged
I have a 1990 Honda Civic Hatchback(base model.) I also have a Viper ESP500......... going to install it shortly. It has 3 channels. I also have a SPAL door popper kit. Is there any way that i can plug up the poppers to the alarm or would be better to plus the alarm to the poppers(popper kit has 7 channels) Please e-mail me with your suggestions. D2P96Escort@aol.com I would really appreciate it. Thank you for your time. Scott
pimpin lo, pimpin slow
auex
Platinum - Posts: 5,041
Posted: December 20, 2003 at 3:29 PM / IP Logged
What you would want to do is wire a relay up to the unlock output and supply that output to the +input of the driver's door popper. Then for the passenger's door you would want to program the alarm to do a progressive unlock. Then wire a relay to use the WHITE/ blue wire (3rd channel output programmed to second unlock) to the passenger's door. If you hook it up this way when you hit unlock it will pop the driver's door and if you hit unlock a second time it will pop the passenger's door.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
pimpcivic
Posted: December 20, 2003 at 8:04 PM / IP Logged
can you please rephrase that in lamense terms. I really didn't understand that because the alarm has one brain and the poppers has one too. How would i work them together? Plus you was saying about hitting unlock and sh*t once and twice..... when it is only a 3 channel how would that work. And can you be more specific on the install of that. I'm not tooooo keen on alarms yet. I would greatly appreciate it. Thank you for you help and everything.... P.S. what kind of relay and everything? and if it is possible can you give me in any way a very well description of how to install it. Thank you. Scott
pimpcivic
Posted: December 22, 2003 at 7:05 AM / IP Logged
can anyone help please would be very very appreciated
Moderator - Posts: 12,488
Posted: December 22, 2003 at 10:10 AM / IP Logged
Hey pimpcivic, what aeux is saying is that the ESP500 has the ability to control both the door popper with just the unlock circuit of the system. Some vehicles have the ability to unlock just the driver's door and when you press the unlock on the remote control again within 3 seconds or so, it will unlock the rest of the doors. Instead of hooking up the second pulse of the rest of the doors, hook it up to the door popper on the passenger side. The door popper's you can install with the supplied CPU or without them by using relay packs set up for the activation of the door poppers.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
