02 Ram sub install
Homicyde
Member - Posts: 20
Posted: December 20, 2003 at 7:35 PM / IP Logged
i have an 02 crew cab ram.  I planning to remove the center seat in the front and install a sealed box running from the rear seat to the dash with 3 alpine type-r 10's firing down. I'll be using a bd1200 punch amp.  My question is: does anybody think this will hit worth a f**k? I have 2- 15's sitting on the rear seat firing towards the rear window.  Its enough to rattle your brain.  Do you think there will be any comparison??? I ready to have my back seat back!!
Homicyde-
forbidden
Platinum - Posts: 5,354
Posted: December 20, 2003 at 7:38 PM / IP Logged
Eliminate the 3 type R's, load in 2 Eclipse aluminum 10's, single voice coil and an Audio Control Epicenter. Build sealed box to approx 2.5 cu.ft and let er rip. This will obliterate the type R's and get some results that you probably be more than happy with.
