1991 Chevy pickup c/k
typeoneunit0
Posted: December 22, 2003 at 3:59 PM / IP Logged
I just install and prestige aps25kb with keyless entry outputs.  the truck has oem power locks.  i need to know if i need wire in relays.  when i connected the wires to the power door locks nothing happened when i set the alarm.  I tested the outputs and they work so i assume that i need relays.
Thanks for your help
draasch
Gold - Posts: 2,172
Posted: December 22, 2003 at 4:57 PM / IP Logged
Make:   Chevrolet
Model: Pickup - Fullsize
Year:    1988-94
This Database Was Last Updated On:    6/9/2003
Index #: 6528
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter PURPLE - AUTOMATIC TRANS. / YELLOW - MANUAL TRANSMISSION
Dome Light WHITE (-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock LT BLUE BEHIND AND BELOW DRIVER #203
Power Unlock BLACK/ RED SPEAKER IN DASH
#203- See Reversal Rest At Ground Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
