1991 Olds Cutless Supream
dtdtdanny
Posted: December 22, 2003 at 4:28 PM / IP Logged
Help:
I have a remote starter alarm in stalled partlyy and I nees the wiring diagram for a negative side install.Most conactions are on thge negative side.
Daniel P truex
draasch
Gold - Posts: 2,172
Posted: December 22, 2003 at 4:55 PM / IP Logged
Make:   Oldsmobile
Model: Cutlass Supreme
Year:    1988-91
This Database Was Last Updated On:    6/9/2003
Index #: 4684
Alarm
Constant 12 volts RED, RED / BLACK AND RED / WHITE - IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) DRIVER KICK PANEL OR COURTESY LIGHT
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock LIGHT BLUE DRIVER KICK #202
Power Unlock BLACK PANEL
#202- See Positive Pulse Door Lock Diagram
Remote Start
Tach Signal WHITE AT ELECTRONIC IGNITION MODULE
Ignition #2 DARK BLUE/WHITE IGNITION SWITCH HARNESS
Ignition #3 IGNITION(3) ORG IGNITION SWITCH HARNESS
Accessory IGNITION(4) PPL/WHT IGNITION SWITCH HARNESS #235
Neutral Safety ORANGE / BLACK (-) AT SWITCH ON TRANSAXLE
Brake Light WHITE OR LIGHT BLUE(+) SWITCH ON BRAKE PEDAL SUPPORT BRACKET
Reverse Light LIGHT GREEN (+) SWITCH ON TRANSAXLE (DRIVER SIDE)
Rear Window Defrost N/A
#235- See Powering Extra Ignitions Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
