fog light wiring confusion
DJFreaq
Member - Posts: 11
Posted: December 26, 2003 at 9:07 PM / IP Logged
I recently bought some good ol' APC fog lights (model# 505065H, oval dual bulb fog lights) and the including wiring diagram DOES NOT match the arrangement of the wires i pulled out! (frustration! fog light wiring confusion -- posted image.)
Here's a scanned jpg of the including *installation instructions*
fullsized here: http://djfreaq.tripod.com/APC_505065H.jpg
If ANY of you have some ideas on wtf i'm supposed to do, I would really apprecaite it, my friend and i have the whole layout taped and laid out on my kitchen table... we're scratching our heads.
Adam
Riding a Taurus, yea... a Taurus. Jelly Bean Machine to the Extreme. :P
DJFreaq
Member - Posts: 11
Posted: December 26, 2003 at 9:08 PM / IP Logged
OH yea, one more thing what is the "Car Corner Lamp" in the enlarged schematic.??
Teken
Gold - Posts: 1,492
Posted: December 26, 2003 at 9:19 PM / IP Logged
Your link does not work. Secondly, I do not understand what it is you dont know?
Looking at this very fuzzy picture seems pretty straight forward.
All the wires starting from the left are very direct. On the upper left is the fuse, and that lead is connected to the batteries positive (+12) terminal.
The other four ring terminals are the chassis ground terminals, which you attatch to the vehicles frame.
The only thing I can not read or see well is the last connection on the lower right. which comes out of the fog light.
Regards
EVIL Teken . . .
DJFreaq
Member - Posts: 11
Posted: December 26, 2003 at 9:35 PM / IP Logged
damnit, stupid link, i saved the jpg wrong so it f**cked it up. here's the PROPER link to the wiring harness::: http://djfreaq.tripod.com/APC_505065H.htm
what's confusing me is the wires leading to the ground, it included no seperate wires to do the job with. Also the wires that power the headlamps are white not blue so i'm just assuming, the connectors don't match the image.
I think I'll be able to install it, but i would like some more tips, i think the wiring thing was just POORLEY made.
adam
DJFreaq
Member - Posts: 11
Posted: December 26, 2003 at 9:43 PM / IP Logged
oh yea, and the lower right is nice and clear in the big image, i don't know what the "Car Corner Lamp" thingy is.
Teken
Gold - Posts: 1,492
Posted: December 26, 2003 at 10:06 PM / IP Logged
OK, in the image you have provided. The upper box labeled (3) has a red power wire, this is normally wired to a *switched +12 power source.
Meaning it is only on during operation of the vehicle. It is to light up the LED in the switch, and provide power to turn the lights on-off.
Next, the lower picture indicating to attatch it to the positive corner lamps is odd, but I assume this is to turn on the side markers of the vehicle while the fog lights are on.
I have never seen this done before, never mind instructed to do so. If you do not wire it in, the lights will still work fine.
As for the wiring colors, it doesnt matter so long as ALL the wiring harness is connected to the appropiate colors. That is common sense, and I do not see you doing it other wise.
Does this answer your Q?
Regards
EVIL Teken . . .
Teken
Gold - Posts: 1,492
Posted: December 26, 2003 at 10:14 PM / IP Logged
So long as EACH fog lights negative (-) wire is connected to the chassis you will be fine, and it will operate. If you have to attatch longer wires because they are too short. Then do so, keeping in mind that they should be as short as possible and use the same size (guage) of wire for the ground termination point.
Regards
EVIL Teken . . .
DJFreaq
Member - Posts: 11
Posted: December 27, 2003 at 12:08 AM / IP Logged
Thanks for info Tek, i really appreciate it i will now be able to install this without much difficulty.
Thanks a ton. hopefully this help everyone
Teken
Gold - Posts: 1,492
Posted: December 27, 2003 at 12:43 AM / IP Logged
The last thing I would like to impress upon you is the one connector wire coming out of the fog light.
It is the one labeled *Connect to corner lamp* this wire is *hot* or supplying a constant +12 volt, when turned on.
If you are not going to hook up this wire coming out of the fog lamp assembly, please ensure you do cover it up with the proper electrical tape or end cap.
Other wise, if it is allowed to touch any metal part of the vehicle, it will short out the fog lamps.
Best of luck in your installation.
In closingm, please ensure you do install the drain spout, assuming it has one in the down ward position, and do not turn the lights on-off in rapid succession, as this will shorten the bulb life.
Regards
EVIL Teken . . .
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
