Help with amp choices
Kaotic
Posted: December 29, 2003 at 11:25 PM / IP Logged
Hey guys...I have a 1996 Impala SS and i just finished the rear trunk layout in fiberglass which holds 2 air tanks for the air ride on each side, 2 fans in the rear, an enclosure built to suit the floor of the trunk w/ 2 12" Swiss Audio SWC's firing into the cab of the car through the rear deck, the car is set up at the moment to run 2 amps in a false floor with a plexiglass Swiss Audio logo in the recess and a capacitor on one side and distribution block on the other. now heres my question. Given that i am running 2 amps (1 for subs and 1 for rear 6x9's and front seperates) what are my best options based on Swiss's amps. Reason I ask is because I am new to Swiss audios line as well as high end stereos. I am a body man/fabricator and i work at a custom shop. Th efiberglass install was a joke to do but when it comes to something as easy as choosing Amps...Im in a daza
www.swissaudioinc.com
sonicsound
Copper - Posts: 100
Posted: December 31, 2003 at 8:09 PM / IP Logged
Use an SDX series for the subs if they are dual 4 ohm voice coil subs and use the smr6004 for your 6x9's and components
Sonic
Pioneer AVH-P4000DVD
Zapco 360.4
Zapco 500.1
Zapco SP-4SL Processor
Two JL 10 W3v3d2
Alumapro 15 Farad Cap
Kaotic
Posted: January 01, 2004 at 2:22 PM / IP Logged
Nice Call!!!!
Thats pretty much exactly what i had priced out as my No. 1 Option..Cool
Thanx
Kaotic
Posted: January 01, 2004 at 2:29 PM / IP Logged
http://www.swissaudioinc.com/woofers/swl.html
The subs are dual 4Ohm voice coil 12", I was looking into the SDX1000 amplifier. THe only catch to any of this is that i built the enclosure to house the 2 subs seperately with a wall in the middle of the enclosure in case one sub should fail the other isnt trying to push twice the volume. Now will there be a problem with runing a 1 channel 350Watt setup in this configuration or should i run a stereo setup with a 6004 running subs and another for fronts and decklid.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
