my light turn off
Overcranked23
Copper - Posts: 67
Posted: January 01, 2004 at 8:32 AM / IP Logged
my cars running lights on my Subaru imperza 93 turn off with the ign. if I leave them on and turn the car off the lights go out. then when I turn the car on bam there are the lights.; I think this is the best thing since sliced bread. anyone know how this is set up or how to set this up please let me know I plan on diond it to all of my cars.
Nick                                                   my light turn off -- posted image.
don't fowl the track
Overcranked23
Copper - Posts: 67
Posted: January 03, 2004 at 8:01 AM / IP Logged
Hey I would really like someone to give me a hand on this please Don't make me have to post again to get it on the top!!!???
auex
Platinum - Posts: 5,041
Posted: January 03, 2004 at 9:09 AM / IP Logged
Pin 86 ign, 85 ground, 30 power/ground feed going to light switch(cut this wire), 87 wire coming from light switch. It works off the same idea as a normally open starter kill system. The only thing is that the lights will not work unless you have the key in the run position. It will be similar to this diagram.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Overcranked23
Copper - Posts: 67
Posted: January 03, 2004 at 5:35 PM / IP Logged
ok now how do I add lights to this besides the factory one's that are aready hooked up
I want to add a back up sensor (mabye) Bigger reverse lights and a set of running lights?
Advice???
