ground noise
rudbwoy69camaro
Silver - Posts: 350
Posted: January 01, 2004 at 12:08 PM / IP Logged
ARGH.  I hate that high pitched "whizzing/whining" noise when you have the head unit on.  I have a vehicle power inverter, and whenever it's on, I get that noise.  I forgot the name....ground isolator?  Please help me.  Thank you in advance for your time.
Reeceddogg
Copper - Posts: 331
Posted: January 01, 2004 at 4:26 PM / IP Logged
I had the same problem in my car and the only thing that worked was moving the inverter away from the head unit with an extension.
Teken
Gold - Posts: 1,492
Posted: January 01, 2004 at 5:11 PM / IP Logged
Reeceddogg is correct in terms of the simple solution. The invertor needs to be relocated as far away as possible.
The AC power that is being generated from the invertor is being allowed to leak out. The excessive EMI / RFI is being radiated out, and inducing other wiring within your vehicle.
That is why some brands cost alot more than others, given the same STATED power output. What they lack is proprer shielding in the casing, and negative feed-back generation to reduce the amount of hum / noise coming off of the unit.
Regards
EVIL Teken . . .
rudbwoy69camaro
Silver - Posts: 350
Posted: January 01, 2004 at 8:18 PM / IP Logged
It's a vector.  I bought one from Costco, a coleman one and that thing sucked.  trying to watch a dvd on the laptop and we had an fm modulator to have in "stereo"  and it had so much ground noise.  the vector one wasn't that bad, that's why I kept it.  So there is no such device I can put on the head unit to stop it?
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
