Alternator / Battery / Both?
jpilson21
Member - Posts: 6
Posted: January 03, 2004 at 9:03 AM / IP Logged
It appears that I have 3 choices for giving my 97 Dodge Ram truck basic electrical needs plus enough power for a competition audio system. Does anyone know for sure which option is safest, most reliable, and the most durable?
Option 1 is to add a 200 amp alternator.
Option 2 is to add a second battery to the truck.
Option 3 is to add both, and have the audio system and nothing else powered by and connceted to the second battery.
The current alternator only puts out 117 amps, which clearly is not enough current for the 2 Lanzar amplifiers I'm putting in. The amps total 2000 watts (1000 watts RMS).
Any feedback on this is appreciated.
auex
Platinum - Posts: 5,041
Posted: January 03, 2004 at 9:13 AM / IP Logged
You need to state what kind of competition you will be in, if it spl then a bank of batteries is probably more important, if sq the the alternator/battery will probably be the best to maintain a steady flow of power.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
bfog99
Copper - Posts: 212
Posted: January 03, 2004 at 10:40 AM / IP Logged
The only reason a second batteryu would be any good to you is if you plan of using the stereo with the car off. My suggestion would be the alternator.
Alpine Guy
Platinum - Posts: 2,478
Posted: January 03, 2004 at 6:31 PM / IP Logged
I 2nd the alternator
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
